Might be that the other part numbers will fit but there are minor differences.  Who knows.
Really though, a 280ZX gear reduction starter is the way to go.  Smaller and less drain on the battery.
https://proampusa.com/UnitSearch.aspx?A1=1982-Nissan-280Z @ 280ZX-2.8L-Starter
There's an easy way to check part numbers you're overlooking. Amazon.com, rockauto.com, oreillys.com, advanceauto.com, autozone.com all have the option to enter your car. Year, make, model. Once you take 1 minute to do that they will tell you if it fits or doesn't fit. Like adjusting the valves, the feeler gauge fits or it doesn't fit.
You have to do some reading wich should only take a minute or two.
Good luck with your starter. If you don't want to pay your mechanic and want to save money do the research and install it yourself. Personally I think the Datsun Z is the easiest starter I've ever installed. You install it coming down, most others you must lay under the car and hold them up. It's a real bitch.
13 hours ago, jalexquijano said:
Hahaha...  See.. Amazon JUNK.. Read the  review at the bottom of the page...  This one costs  $45,36  AND IT'S  JUNK!    It says the starter was installed and lasted not 10 starts!  :facepalm:
On 7/3/2016 at 2:49 PM, madkaw said:
Great story !
I once put mine on a trailer with only starter torque. The only thing I worried about was every time the starter turned the engine over it would push the trailer forward and backward. I was afraid the ramps would come out of the hook... Stock starter is fine!
  • Who's Online   0 Members, 0 Anonymous, 1,413 Guests (See full list)
