For some background I have a '71 Datsun 240z and have made a few modifications to it so far
- replace solenoid, new plug wires, new spark plugs, cleaned the carbs.
it worked fine until the engine sat for awhile. I put on a new valve cover and a new exhaust. since then I can't get the thing to start. Now every time I try to start it it'll sound for about 2 seconds like its going off of starter fluid then cut out, totally unresponsive to the throttle. it'll only do this for the first go around and after that i can crank for days and nothing happens. This makes me think its a fuel/spark issue because its getting flooded so it only happens the first time, however, since this problem started happening i've tried the following.
- checked the fuel to the carbs. i took off the hose and cranked the engine and got a lot of fuel coming out
- i made sure that the plug wires corresponded correctly with TDC and that the firing order was all correct
- got a new battery
- got new spark plugs
- cranked it with a $^!# ton of start fluid.
I havent adjusted the timing but i'm guessing it should be fine if it was fine before and I never took out the distributor.
any suggestions would be greatly appreciated.
I'm sorry I can't help you more now, I'm using my phone. I can help better in the morning when I have my laptop. Maybe someone can chime in before then?
The nozzles are at the very bottom of the carbs and should move move freely with the throttle linkage. 2.5 turns counter clockwise is a base starting point. Mine run best at three to the 3.5 turns down.
Let me get back to this in the morning,  I'm enjoying some cold beers at the moment. LOL
How long is "a while"?  And where did it sit?  Did you remove anything besides exhaust when you replaced the exhaust?
These kinds of problems are usually caused by the stuff that you're sure can't be the reason.
forgot to mention i've added about 4 gallons of new gas + additive. im not sure at what rate the new fuel gets mixed in but i've cranked it a a lot since putting new gas in so that may or may not be the case. and it sat for a few months. if i had to put a number on it i'd say 3-4 months
Edited by thosearezs
Everybody's just recommending that you check that the carbs aren't gunked up.  Even a dry carb will get some slight corrosion of the aluminum that can cause friction, if it's in a moist environment.  They're sensitive creatures.  Sometimes it's worse when they're off because they might sit tilted.  Then the varnish sticks on unusual parts.
