July 3, 20169 yr comment_498029 I'm thinking if you removed the float chamber lids you'd see something similar to mine when I first bought the car. The floats should sit fairly level or parallel with the lids. The opposite of my picture. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498029 Share on other sites More sharing options...
July 3, 20169 yr comment_498059 Fuel at the carbs does not necessarily mean fuel in the engine. There are small screen filters in the banjo bolt. The needle and seat maybe screwed. The hoses from float bowl to carb maybe kinked Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498059 Share on other sites More sharing options...
July 4, 20169 yr Author comment_498068 took my floats out and they're NOT parallel like yours @siteunseen. checked the hoses and they're fine too. but i'll keep checking other areas of the carbs not to deviate from the carbs but could it be a wrong firing order? I had to find the position of the first sparkplug by putting my finger over the whole and checking for pressure to stop. I know this is a janky fix but i had friend watch the cam lobe through the oil fill cap Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498068 Share on other sites More sharing options...
July 4, 20169 yr comment_498069 Remember....the rotor turns counter clockwise. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498069 Share on other sites More sharing options...
July 4, 20169 yr Author comment_498073 cleaned out the bowls. they had some gunk in there definitely some other information: when i try starting it it'll make this sound like its firing every 1 or 2 seconds but never actually starts running Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498073 Share on other sites More sharing options...
July 4, 20169 yr comment_498080 Correct ignition timing and firing order is critical. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498080 Share on other sites More sharing options...
July 4, 20169 yr Author comment_498083 while cranking the engine and adding starter fluid i adjusted the timing and it made no difference in either direction. ALso when i found TDC the notches in the harmonic balancer were way off. i was assuming that the cam lobe had to be straight up for it to be TDC. is it possible that the harmonic balancer has just slipped a lot or what? Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498083 Share on other sites More sharing options...
July 4, 20169 yr comment_498085 You've reached thrashing about stage. Once you get here it's best to go back to square one and build back up. That would be to confirm that the plug wires are in the correct holes. Since you didn't remove the oil pump, it's probably safe to assume that the distributor is installed correctly. Take the cap off, turn the engine until the rotor is pointing forward and the timing mark is at zero. Then put #1 in and install the others in the right and order and rotation direction. People get it wrong all the time. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498085 Share on other sites More sharing options...
July 4, 20169 yr comment_498096 The first two lobes should be like a V, not straight up, maybe 11 o'clock and 1 o'clock? Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498096 Share on other sites More sharing options...
July 6, 20169 yr comment_498202 On 7/3/2016 at 7:44 PM, Zed Head said: ....Since you didn't remove the oil pump, it's probably safe to assume that the distributor is installed correctly.... Not necessarily. Find TDC on the compression stroke for the #1 cylinder independently of the distributor and timing marks on the harmonic damper. Start the firing order for the plug wires from which ever position in the cap the rotor is pointing to. If you still have points set the ignition timing using the "dead timing" method (after checking/setting the point gap). Also, I don't see any confirmation in your posts that you have spark. Make sure you have spark at the plugs before going crazy with the timing and firing order. Perhaps there is a problem in the primary wiring. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498202 Share on other sites More sharing options...
July 6, 20169 yr comment_498203 On 7/3/2016 at 7:44 PM, Zed Head said: ....Since you didn't remove the oil pump, it's probably safe to assume that the distributor is installed correctly.... Not necessarily. Find TDC on the compression stroke for the #1 cylinder independently of the distributor and timing marks on the harmonic damper. Start the firing order for the plug wires from which ever position in the cap the rotor is pointing to. If you still have points set the ignition timing using the "dead timing" method (after checking/setting the point gap). Also, I don't see any confirmation in your posts that you have spark. Make sure you have spark at the plugs before going crazy with the timing and firing order. Perhaps there is a problem in the primary wiring. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498203 Share on other sites More sharing options...
July 6, 20169 yr comment_498214 You're right. I even forgot that I gave somebody the same advice just a short while ago, that there was no guarantee the PO had it right. Even referred to it in my post above, "people get it wrong all the time". They get the oil pump installed wrong too. In that previous thread, the PO did have it wrong and the new owner put the wires where they were supposed to be. When he put them where they weren't supposed to be it worked like it used to. Link to comment https://www.classiczcars.com/forums/topic/55742-wont-start-determined-to-not-take-it-to-a-mechanic/?&page=2#findComment-498214 Share on other sites More sharing options...
