This is on my 76 2+2. The other day my daughter was following me home and when we arrived she said my right (passenger) side brake light wasn't very bright.  I don't know how long it's been like that, may be ever since I bought the car a couple of years ago and then some.
Anyway, when I put the brakes on, the parking element on the right side lights, not the brake element. When I turn the parking lights on, the correct parking element lights, but then if I also put the brakes on, neither element lights. I tried switching bulbs, but it doesn't change anything. The left side (driver side) lamps seem to work fine.
Any ideas where in the wiring harness I should start to look. Again, I have no idea how long it's been like this, but it's almost like a prior owner got some wires crossed or something. I don't think it could have come from the factory like that 40 years ago.  I did check the connector proximal to the lamp and it seems fine. I didn't yet pull the passenger's seat out to get at that connector. But again, it seems more like wires somehow got crossed verses just a dirty connector or ground?
Thanks
Gary
Edited by Gary L
https://www.classiczcars.com/topic/56009-tail-brake-light-issue/
Well, just checking the parking light pin in the sockets, I have just over 10 volts on the left side and only 5.3 volts on the problem (right) side. So I'm sure that is part of the dim issue, but doesn't explain why the brake light element doesn't light at all on that side.
Don't know if you're grounding to the ground pin or the body when you take those measurements but the ground side could feasibly be the issue.  Find that splice.  It's probably one of those scary looking crimp splices, buried in some tape somewhere.
Edit - actually, take a measurement from the power pin to ground first.  That will tell you if the ground is bad.
Edited by Zed Head
My battery is only 2 years old and measures 12.03 volts. When I measured at the socket, I put the neg on the outside of the socket and then touched the parking light pin getting the 10 volts and 5.3 volts. Looking at the schematic, isn't the ground for both the rear lamps the same and so I'm not sure why one would work fine and the other not if it was a ground issue?
There's a splice along the way.  The right side has essentially two ground points, one at the splice and one at the terminal end of the wire.
I put a picture n my other post.  Maybe you're reading your own schematic?
Edited by Zed Head
Nissan would make splices in the harness for efficiency sake. Under the loom tape in the harness somewhere will be a small splice. They strip a little section off a wire and then strip the end of the other wire and attach them to each other with a small copper crimp. They can be hard to find. Sometime they corrode...another thing to check is take your meter and with a long lead or a long piece of wire tie the black meter probe to the negative battery post and post up your voltages again...
