I got the inspection plate off, video coming, looks pretty good, but I would like to freshen up the seam sealer around the base. I have some butyl seam sealer that would work great where I can get to it but the back and the side towards the middle of the car have very limited access. I am thinking plumber putty, make up a rope of it and snake it back then work it in.
https://www.classiczcars.com/topic/56083-280z-air-chimney/
Use Duct Seal. Best stuff ever. All electricians, plumbers and HVAC use it to seal penetrations.
Never hardens. A 1 pound block will last forever. You will use it around the house too.
Example here.
https://www.amazon.com/Gardner-Bender-DS-110N-1-Pound-Compound/dp/B000BO8XD6/ref=sr_1_2?ie=UTF8&qid=1472663530&sr=8-2&keywords=duct+seal
https://www.classiczcars.com/topic/56083-280z-air-chimney/#findComment-502222
too late plumber putty was done right after I posted.  the cover is removable so will check on periodically and report back. Patcon the prob with any kind of sealant that is even remotely sticky to hands is the problem of getting it in place in the back of the chimney. I had to work it with my hands/tools/anything I could lay my hands on to try and form it. I ended up using a plastic dowel to reach the last bit that I could not squeeze my hands into. I don't think I could have enough control with a delivery system that used a tube. I know plumbers putty never hardens, I painted over it anyway. The Lumens stuff looks like a good way to go. I was planning on using my butyl caulk but after using it on the windshield there was no way I wanted to mess with it with limited access. It hugely messy and gets everywhere.
https://www.classiczcars.com/topic/56083-280z-air-chimney/#findComment-502226
I learned a trick from a commercial glass installer on poly butyl.  They used Dollar Store Palmolive dishwashing detergent on their fingers and putty knives to smooth it out.  It won't stick and pull when using that.  I use it on my fingers smoothing silicone caulk.  Works great.
https://www.classiczcars.com/topic/56083-280z-air-chimney/#findComment-502228
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
