S30Driver Posted September 12, 2016 Share #13 Posted September 12, 2016 Great news that you have a trailer coming to take the car the rest of the way and not risk motor damage. Pull the plugs when you get a chance to see what they look like, and look at the oil on the dipstick. No sign of moisture on either would be good. Best of luck to get home safely. Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503055 Share on other sites More sharing options...
ABCar Posted September 12, 2016 Author Share #14 Posted September 12, 2016 25 minutes ago, Zed Head said: Ouch. Two hours is about Des Moines, isn't it? He has a situation. So, cruising on the freeway and the temperature shoots up? Not good. Mine did that once but it was because a heater hose split. Pretty obvious. If it went two hours, you'd think the radiator and shrouding and air flow were sufficient. Check the radiator for a plastic bag or large bird blocking air flow. Seems more likely that the head gasket is leaking tough, doesn't it? No Birds or bags. Something "changed" I watched that gauge like a hawk because I did not know the car. It was planted in the middle like a rock...then at about two hours it went up to ~240 and stayed. I would park and let it cool off...and even bled out some steam through the pressure release cap...and it would start stay cool for a short time...then like clockwork...would work its way up again. I did this about three times and gave up. Luckily a friend picked me up in his plane and flew me back. Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503056 Share on other sites More sharing options...
S30Driver Posted September 12, 2016 Share #15 Posted September 12, 2016 Not sure where you are in Michigan, there are some ClassicZ members there, amongst them is a trusted senior member @Jeff G 78. He lives near Northville, and could be very helpful to resolve the overheating issue. (Glad that Trump could divert his plane off the campaign trail to come pick you up) Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503057 Share on other sites More sharing options...
ABCar Posted September 12, 2016 Author Share #16 Posted September 12, 2016 (edited) 33 minutes ago, S30Driver said: (Glad that Trump could divert his plane off the campaign trail to come pick you up) Thanks for the reference too. I am on the other side of the state...Kalamazoo. Edited September 12, 2016 by ABCar Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503059 Share on other sites More sharing options...
jfa.series1 Posted September 12, 2016 Share #17 Posted September 12, 2016 While the radiator is a more likely culprit, don't overlook the water pump. Just because it turns and there are no visible leaks, there might be internal damage to the impeller vanes that reduces the volume being circulated. Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503061 Share on other sites More sharing options...
Stanley Posted September 12, 2016 Share #18 Posted September 12, 2016 If coolant level remains steady the gasket is probably OK, but radiator shop can test for a small leak / pressure. Easy to check for bad water pump. Let it warm up a little and remove radiator cap. Let it idle until it gets to 180F or whenever the thermostat opens. Look in the filler hole; you should be able to see the coolant flowing through briskly. You could also feel it pulsing in the lower radiator hose, but that's not as safe to check with the fan and belts spinning nearby. If not probably bad water pump or blocked radiator. If it's blocked you might be able to feel some cool spots on the core while it's running. How hot was the weather when it was happening ? Uphill or level ? Steady cruising or stop and go ? Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503070 Share on other sites More sharing options...
Dave WM Posted September 12, 2016 Share #19 Posted September 12, 2016 One of my best tools is a rad pressure tester, great for finding leaks and testing rad caps. Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503073 Share on other sites More sharing options...
madkaw Posted September 12, 2016 Share #20 Posted September 12, 2016 I'd rent the free coolant pressure tester from autozone. Run the car with it on there and if pressure starts climbing - start pulling spark plugs till you find which - if any- hole is the problem . Assuming this is a HG issueSent from my iPhone using Classic Zcar Club Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503074 Share on other sites More sharing options...
ABCar Posted September 13, 2016 Author Share #21 Posted September 13, 2016 14 hours ago, Stanley said: How hot was the weather when it was happening ? Uphill or level ? Steady cruising or stop and go ? 18 hours ago, jfa.series1 said: While the radiator is a more likely culprit, don't overlook the water pump. Just because it turns and there are no visible leaks, there might be internal damage to the impeller vanes that reduces the volume being circulated. Weather was 75 ish steady Interstate. It was 515 degrees f inside my head. ; I will check the water pump. I doubt it is radiator because it is near new I think...will still check of course Car coming home this week...will diagnose and post final results. Thanks all for your input. This is a good forum from what I can see so far. Link to comment https://www.classiczcars.com/topic/56167-overheating/?page=2#findComment-503107 Share on other sites More sharing options...
