78 280Z spare tire compartment suggestions
I am beginning to formulate the battle plan for replacing the floor pans and front frame rails on the project car.  It looks like there are a few good options available for purchasing new
pieces.  Other small areas that should be replaced I am pretty confident I can fabricate some repair pieces with 20 gauge sheet metal.  The spare tire compartment is in real poor shape.  I do not have any confidence of fabricating that part.  I have looked at a few trunk sections from some newer vehicles and have come very close with the same dimensions as the original.  Any thoughts on cutting one out of a salvage yard car and dropping it into the 280Z?  The 2 hanger brackets on the bottom of the spare tire compartment could be easily welded on the replacement component.  There are no intentions of this project being a show piece, just a solid fun runner on a budget .  It seems that the depths of the newer car compartments are a bit deeper than the original, but the diameters are nearly identical.  I am sure roaming through our local Pull-A-Part I can locate  something very close.  Any helpful suggestions welcomed.  Thanks again, John-Lugoff, SC.
Thanks for the responses.  Been very busy at work this past week and several other projects going on at home and church, so the Z project got put to the back burner.
Did not even check my e-mails or Z-car site.  I will have to check out the map for the GA location and see if it is any where near our daughter.  I never realized how big a state Georgia was until they moved there and purchased a home .  They are about 4-4-1/2 hours away from us.  We will see how things work out.  Shipping such a part would be awkward and costly.  Thanks again, John-Lugoff,SC.
  • Who's Online   2 Members, 0 Anonymous, 1,508 Guests (See full list)
