Front oil seal is the same as the 5 speed with part number: 32114-Y4000. $5.09 at Courtesy Nissan.
Nissan supplieed me a NOK. Type: AH1679G. Size: 30/45x8mm.
Not sure if the rear is the same as the 5 speed. The shaft diameter is the same, but Im not sure about the outer seal diameter. I have a 280Z 5 speed seal and the dimenssions. It also fits the 71C transmissions. The part number is 32136-U010A.
You could check your outer diameter. The 5 speed has a NOK Type: 400402N. Size: 35/50x11mm.
Edited by EuroDat
https://www.classiczcars.com/topic/56261-original-trans/#findComment-504060
  • Who's Online   0 Members, 0 Anonymous, 1,304 Guests (See full list)
