i am near the point of needing a camshaft, as i hope to have the head back from the shop this week. kind of hard to make a decision, but i have narrowed it down to 2. so, my question is
are any of you using either of these, and if so, how do you like it. my engine is a l24 that is .75mm over and the pistons are .5mm out of the block. the head is a E31 with 280 valves. i have weber carbs, 3-2-1 header and pertronix ignition and a fidanza flywheel.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1153&sb=2
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1152&sb=2
thanks all   sb
https://www.classiczcars.com/topic/56312-camshaft-questions/
I personally haven't been able to tell a difference between the Schneider cam(480/280) and the Isky (490/290) . Don't think you can go wrong with either. I think only a dyno would tell me. I got both cams to idle okay and both make good power
