Can I use just the outer OE valve spring to get the wipe pattern right? Honsowetz's book uses special "set up springs" that I don't have but I would like the least resistance I can get while doing this. All my lash pads are .190s and I figure I'll do a lot of filing to get them right. Any experience on which to use while doing this would be appreciated.
Thanks, Cliff
https://www.classiczcars.com/topic/56320-cam-setup-question/
