9 hours ago, duffman said:
How are you doing a repetitive test run to compare results on an apples vs apples basis?
Flat road, 3rd gear....pull from 3K rpm.  It's certainly not a dyno, but I try to get 2-3 pulls in so that I can make sure I'm getting repeatable results.
I tried 155/225...way lean..in the 14's, didn't get a log.
Threw in my 215 corrector....for a 155/215 combo....
36320007332_bee737ed7a_o.jpg81017 by blodi, on Flickr
I also ordered a 35 exhaust jet to start combating the accel pump jet at the low end.
14 hours ago, 240260280 said:
Do you think the meter's calibration was off for the 165/225 run posted above?
Maybe? I could reinstall that combo, recalibrate and then try again. Because to be honest...that combo should have made more sense looking at the latest results.
  • Who's Online   3 Members, 0 Anonymous, 1,417 Guests (See full list)
