280Z EFI parts and turbo manifold
I was trying to sell the setup complete, but doesn't look like it's happening, so it's time to part it out. Prices do not include shipping, and that'll be extra. I am open to reasonable offers as well. I take paypal, or if you're in South Florida, I can meet up and save you on shipping!
Here goes!
- N42 intake manifold with custom fuel rail with -6AN fittings. Uses Bosch EV6 injectors currently using 19lb injectors, the possibilities are endless for injector sizes. Manifold was machined to fit them, so this setup has to go together, I will not separate the rail and manifold. Some components were removed from the manifold, egr, dashpot, auxiliary air regulator, and 7th injector. - SOLD
- 2 x 1975 ECU. I bought a spare as a backup, it was tested on the car and ran fine. - $75 each
- 2 x Airflow meter. Same as ECU, bought a spare as a backup - SOLD
- Wiring harness with EV6 injector pigtails. If you need it for stock injectors, you'll need to cut the pigtails off - $75
- Stock fuel pressure regulator - $35
- Stock airbox - $30
- Rubber intake boots (no tears) - $30
- Bosch 044 fuel pump - SOLD
- 16" electric fan and thermostatic switch with relay harness - $60
-  L28ET turbo manifold. Modified for a T4 turbo, and has a v-band flange for an external wastegate - SOLD
14572850_10207372768097069_734809309373699196_n.jpg14519908_10207372768337075_2956311489474529396_n.jpg14563415_10207372770457128_4663608483304476971_n.jpg14600941_10207372770017117_7247211158594872532_n.jpg14642079_10207372770177121_621632045879732470_n.jpg14666126_10207372768937090_8915525848414084298_n.jpg14670904_10207372769417102_1873902073730437355_n.jpg
Edited by Serban
https://www.classiczcars.com/topic/56376-280z-efi-parts-and-turbo-manifold/
My plan was to go full standalone and turbo the car, but took a step back and decided to simplify everything and add a set of carbs. Right now my 280 is running a couple of round top carbs.
The obvious 280z parts are used, one AFM and ECU came off my car, so they are used, the backups were also purchased used. I don't know the story of the turbo manifold, it may even be coated, this is how I got it.
Intake manifold was all my doing when I bought my car a few years ago, it had one bad injector and rather than replacing it for cheap, I spent quite a bit more getting a custom rail made, that fuel setup has about 15k miles on it over the last 3 years.
I don't know the CFM rating on that fan, it was a take off from a Cobra replica, the guy did 2 smaller fans, the fan has maybe a few hours on it.
Fuel pump, maybe 5k miles. It was replaced after my stock one failed.
I thought about keeping this stuff, and building an engine for boost, but it's time to clean up the garage.
31 minutes ago, madkaw said:
Too bad - looks like a MegaSquirt and some wiring and you were there.  I did the same exact thing to my intake or I would be making an offer. Nice looking turbo exhaust manifold!
good luck
Thanks! I was close, but in the end I chose the simpler, less expensive route. I still needed to figure out a tps, plus I'm terrible with wiring, and worse at trying to figure out how to tune with a laptop.
I actually picked up an engine a few months ago, supposedly fully built L24 with a draw through carb setup. I still haven't torn into it, looks to be an old setup from the 70s or 80s, but I like the uniqueness of it. So the turbo dream is still not dead just yet! Here's the thread for reference: http://www.classiczcars.com/forums/topic/55823-draw-through-carb-turbo-setup/
  • 5 months later...
  • 5 months later...
