Hello again,
Been quite a while since I posted here.  How’s this for an update?
September 2006
Acquired my uncle’s 1976 2+2.  He got it around 1980 or 81.  Drove it from Houston, TX to Glendale, CA.  It’s not in the best of shape.  Has over 300,000 miles on it.
October 2006
After getting my 76 2+2  that was originally my uncles checked out at a shop in Glendale, CA, it was evident that the car was a rusty mess.  Too many years in east Texas rain.  Began looking for a rolling shell. Engine/transmission OK, so are interior parts and other odds and ends.  Gonna keep the rims too.  14” Western Mesh from who knows how long ago.
June 2007
Not much luck finding a rolling shell, but did find a couple running cars from Bakersfield to near Sacramento.  Decided to take a long day trip to check them all out on a Saturday.
1st up was Bakersfield; a 78 that ran strong, needs full interior, suspension work, but more rust than I’d like.
2nd was near Fresno.  Another ok runner needs interior/ bumpers, all sorts of odds and ends.
Last for the day was Auburn CA.  Found original owner 75.  This is the car I bought. 140,XXX miles, factory A/C. Needs brakes and paint, but the car is 100% intact.  Most everything original.  Never in an accident.  Almost everything works, except an early 80’s radio (ended up being a fuse) and the washer fluid pump.  Least amount of rust on a Z I’ve seen in person.  So far as I can tell, just spotted rock chip rust hear and there.  Floor boards are good, rails good, spare wheel area good.  Put deposit down to pick up the next week.
Had brakes worked on by the PO’s mechanic in Auburn during the week, and drove it back the next Saturday.  The car hadn’t been on a long trip in a while but made it back no problems.
June 2008
At a shop in Glendale, CA, got the 5-Speed swapped into the car and they stripped the rusty 76 of all salvageable parts.  Put the 14” western rims on as well.
July 2008 to August 2015
Life happens:  Got laid off, found new job, got married, bought apt. in Burbank, CA.
All the while, kept driving the car and doing fluid changes and what not, but that’s about it.
September - October 2015
My brother moved to Lancaster briefly, so finally had a place to do some work on the car for a couple months, as much as time and budget allows.
So began a serious tune-up and replaced the following;
Rubber fuel hoses, Injectors, injector connectors, plugs and wires, distributor cap, rotor, fuel filter, air filter, fusible links and cap,  fram fuel filter before fuel pump, new battery cables, battery hold down, new alternator, belts, oil change, coolant flush.
January 2016
Back to Burbank now.  I can work on the car in the underground garage, HOA is cool, as long as I don’t do fluid changes or jack up the car (can’t anyway as parking spot is on incline) and have to cleanup when done.  No problem there.
Installed battery cut off switch, and notice the 1st of the previous owner’s peculiarities after recently studying the electrical system in FSM.  The fusible link between battery and EFI was replaced with two 20amp reg inline fuses.  Replaced that with a properly crimped and insulated maxi-fuse.
February 2016
Noticed a coolant leak.  Had a shop replace the water pump and gasket.  All good now.
Began replacing all the vacuum lines.  Started slow/ took my time, but got them all done except the brake booster hoses.  Started the car, smoke everywhere.  I went through FSM, and found in the process of replacing vacuum lines I knocked the other electrical connectors around.  They are corroded and just about crumble when touched.
June 2016
Finished replacing all the other electrical connectors, cleaned all the other electrical connections, and replaced bullet & butt connectors. Dyno Label maker with heat resistant labels made this so much easier.
Replaced AFM Boots, PCV Valve and PCV Hose.  Opened up the AFM to have a look, and it seems to have never been opened.  Everything inside was shiny and original.  I sealed it back up and re-installed.  Read to many stories about jacked up AFM’s.  Same with the TPS.
Started the car for the first time in three and a half months.  No problems.  Fired right up and runs smooth, no smoke.
July 2016
Installed re-built combo and turn signal switch.  Installed famous headlight relays and parking light relays upgrade.  They work great.
Installed a set of Hella 500 driving lights under the front bumper.  Wired it up with a proper relay.  Had them laying around for when the “fog” lights go out in my 2005 Jeep Wrangler Unlimited (daily driver).  If you’re gonna have ginormous bumpers may as well use them for something.
Noticed the hazard lights don’t work.  Don’t know when that stopped working, never had to use them.  Turn signals worked no problem.  Cleaned the switch, still no hazards.  Ended up replacing the flasher.  All good now.  Getting to the flasher is something else though.  Mine was original and still screwed down.  Was able to get my hand up far enough to get the wired connector loose and place on new flasher unit.  Zip-tied and velcroed down, all is good.  Also noticed the other electrical connectors under the dash (those I can reach/see) are nice and shiny.
August 2016
Replaced the side view mirror with a chrome 240z style aftermarket mirror.  Old one would crumble and chip if looked at funny.
September 2016
Went over everything done in the past year.  Checked and re-checked.  Found a couple things to tighten up, clean, etc…
November 2016
Suspension needs refresh.  Drives like a squishy bumper car.  Who knows how many suspension parts are original.  It’s next on the list, gonna keep stock. Gonna have to farm this work out.
That’s where I’m at now.  After the suspension is refreshed, I’m gonna work on the replacing all the cooling system hoses. and HVAC seals.
  • Like 3
https://www.classiczcars.com/topic/56492-ten-year-update-and-re-introduction/
Nice.  If you lower the car just a bit it will help the handling a lot.  I've heard/read that the later cars sit a little high because there's certain height the 5 mph bumpers have to be at.  Federal guidelines.  Only mentioning 'cause you're going to work on the suspension.
Yeah, neat story, "rolling restoration" is a lot more fun to me.  Do a few things and drive it for awhile.  I'm scared to do too much, afraid someone's gonna run into me and total the car.  I need struts on my '77 also, push the front bumper down and it almost bounces the front tires off the ground rebounding so fast, but I'm like you and will have to pay someone to do that.
Keep trudging along and you'll never be bored.  :beer:
