Converting 240Z from carbs to injection. Fuel tank?
1 hour ago, madkaw said:
This is what I'm doing . Not sure how this would drop into a stock tank
http://www.tanksinc.com/index.cfm/page/ptype=results/category_id=61/mode=cat/cat61.htm
Works just fine at least in a 280 tank! it's in mine waiting for the day when I finally give up on carbs. Real soon, yeah...
You just have to position it in the right spot so the fuel sender arm clears it. You have control of the length/depth of the frame to get it "just" on the bottom of the tank. The only wrinkle is that the top elbows are too tall. I had to fabricate a hole and cap in the hatch area. No biggy
2 hours ago, madkaw said:
It vents as it returns to the tank
I guess.  It's more of a decoupled loop than a surge tank.  I think I have my mind wrapped around it though.  A vent would be a bad idea.  It would be prone to overfilling and leaking.
Jim, if you get a chance could you post a pic of this? I will have to do this on my Z but keep running into the subframe.
Integrated Engineering makes a Surge tank that includes Internal  mounting for an Bosch 044 or similar pump.. Single or Dual pump versions available. Lots of VW/Audi/Subi guys use them. You can keep the stock 240Z tank, Return lines can route back to the surge tank.
http://www.performancebyie.com/ie-submerged-044-billet-surge-tank
Edited by Chickenman
Added picture
  • 1 month later...
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
