Found this under the dash
1973 240z. Was working on the heater and came across this toggle switch stuffed in behind on dash on the lower right side. Any idea as to what it would control. It's  centered and will toggle up and down but always returns to center.
I was thinking maybe for the antenna. Thanks
https://www.classiczcars.com/topic/56603-found-this-under-the-dash/
Historically, Nissan built the antenna switches into the radio faceplate for the 240 series.  I've not seen a factory radio setup for a '73 so I can't guarantee this.  Does your car have an aftermarket radio?  If so, that might explain how your switch got evicted - especially if you no longer have a working power antenna.
3 hours ago, George_Zed said:
On my 73... marked with red
There you have it - the toggle switch mounted to the radio and controlled by a slider button that is on the top right of the radio faceplate  Thanks George..
