Hi all, I did some upgrades overnight and here are some of the features you can expect to see.  I'm excited to see improvements to the reply editor and leaderboard.  These should be the most obvious.  Enjoy!
  • Auto-saved content in the editor will now expire after 48 hours
  • If you load an editor that has previous auto-saved content you will now be prompted to keep or remove it
  • Escape key will now cancel quick-edit on titles
  • There are now more "save and reload" options in various places to keep your place when editing content or settings
  • When you see a "could not write file" error the file it was trying to write now shows in the error logs
  • You can now quickly edit tags when viewing an item without having to edit it if you have permission
  • If you are using multiple devices to login to a site you will be less likely to be logged out
  • Tags can now be quickly edited when viewing an item
  • Guest terms of service alert
  • Display name history is now available on profile view
  • Leaderboard
https://www.classiczcars.com/topic/56643-website-update/
Recently Browsing 0
