LeonV Posted December 19, 2016 Share #37 Posted December 19, 2016 3 hours ago, conedodger said: Leon, i don't think of it so much as going to the dark side, as I think it is bringing the car into this century. I get the style of the original which is classic, but the accuracy of a modern car. Let's face it. Stop light to stop light, we get beat by minivans. 300HP and almost that in torque evens that out. Controlling it all digitally is icing on the cake. Agreed, it's nice to have reliable, modern tech under the hood. The Rebello motor should be a ton of fun! I went a slightly different direction with my current Z, using 123ignition for timing. Still a distributor but it's digital and I have discrete control of the timing curve. Considering getting the Jenvey Weber look-alike throttle bodies if I go EFI at some point down the road. Keep us posted on your project! 1 Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508412 Share on other sites More sharing options...
FreshZ Posted December 19, 2016 Share #38 Posted December 19, 2016 Leon, i don't think of it so much as going to the dark side, as I think it is bringing the car into this century. I get the style of the original which is classic, but the accuracy of a modern car. Let's face it. Stop light to stop light, we get beat by minivans. 300HP and almost that in torque evens that out. Controlling it all digitally is icing on the cake.what engine and mods do you have that are giving 300hp?Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508413 Share on other sites More sharing options...
conedodger Posted December 19, 2016 Author Share #39 Posted December 19, 2016 51 minutes ago, LeonV said: Agreed, it's nice to have reliable, modern tech under the hood. The Rebello motor should be a ton of fun! I went a slightly different direction with my current Z, using 123ignition for timing. Still a distributor but it's digital and I have discrete control of the timing curve. Considering getting the Jenvey Weber look-alike throttle bodies if I go EFI at some point down the road. Keep us posted on your project! Leon, I wondered about the Jenvey Tbodies. I'm trying to restrain myself from getting too wild. I'll watch for your build. BTW, I bought the smog shop in the same complex as Original Customs so I have rollers we can use for tuning! Not a dyno but we can laptop tune without worrying about traffic... Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508416 Share on other sites More sharing options...
conedodger Posted December 19, 2016 Author Share #40 Posted December 19, 2016 56 minutes ago, FreshZ said: what engine and mods do you have that are giving 300hp? Sent from my LG-D850 using Classic Zcar Club mobile I believe I actually said 250-300HP. Rebello says this combination of forged pistons, stroked crank and lightened H-beam rods makes up to 300HP and 290lbs/ft of torque. I'm using a ported and polished E31 head with big valves that has been modified with injector ports for the Megasquirt Pro EMS. This is all on Dave Rebello's website if you want to check it out... Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508417 Share on other sites More sharing options...
Patcon Posted December 20, 2016 Share #41 Posted December 20, 2016 20 hours ago, FreshZ said: what engine and mods do you have that are giving 300hp? Just remember horsepower takes money! How fast do you want to spend? Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508497 Share on other sites More sharing options...
FreshZ Posted December 20, 2016 Share #42 Posted December 20, 2016 Just remember horsepower takes money! How fast do you want to spend?no need to have to remember that horsepower takes money....that's a well known fact. the real question is how much horsepower can you get doing it right, and doing it once.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508500 Share on other sites More sharing options...
Kurbycar32 Posted December 20, 2016 Share #43 Posted December 20, 2016 (edited) Conedodger it looks like you just bought the same motor I did from Rebello, it's pretty incredible. Here is a list of the stuff I screwed up mostly all from this thread: 1. I should have purchased a new or rebuilt harmonic damper. Looks like you are on top of that. I rebuilt mine after it exploded on the car 2. I should have addressed the flywheel and clutch earlier. I purchased a fidanza aluminium flywheel and centerforce II clutch. No regrets but the clutch engagement takes some getting used to because of the lack of inertia on the flywheel 3. I should have purchased the distributor system earlier. Ultimately i ended up with a 280zx dizzy and it works great and even idles smooth. I cant speak to your EDIS conversion but I should have had the ignition working on the old motor to reduce the amount of variables after the motor swap 4. I needed a fancy timing light with dial adjustment 5. The alternator upgrade and relay kits should be done before motor swap. I have occasional low voltage issues and I bet that would wreak havoc on a computer controlled ignition. If i think of anything else ill post it Edited December 20, 2016 by Kurbycar32 Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508533 Share on other sites More sharing options...
conedodger Posted December 20, 2016 Author Share #44 Posted December 20, 2016 Thanks! Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508558 Share on other sites More sharing options...
LeonV Posted December 21, 2016 Share #45 Posted December 21, 2016 Let me know when you're ready for tuning, Bob. I can get you a discounted rate on dyno rental at Works Motorsports at Sonoma Raceway. I've tuned a few Megasquirt setups and would be happy to assist. Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508620 Share on other sites More sharing options...
LeonV Posted December 21, 2016 Share #46 Posted December 21, 2016 14 hours ago, Kurbycar32 said: Conedodger it looks like you just bought the same motor I did from Rebello, it's pretty incredible. Here is a list of the stuff I screwed up mostly all from this thread: 2. I should have addressed the flywheel and clutch earlier. I purchased a fidanza aluminium flywheel and centerforce II clutch. No regrets but the clutch engagement takes some getting used to because of the lack of inertia on the flywheel I have a feeling that the touchy clutch engagement is due to the clutch and not the flywheel. I'm running a 10lb Fidanza with a stock clutch (at 194hp/180lb-ft at the wheels BTW) and engagement is nice and smooth. FWIW... 1 Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508621 Share on other sites More sharing options...
conedodger Posted December 21, 2016 Author Share #47 Posted December 21, 2016 11 hours ago, LeonV said: Let me know when you're ready for tuning, Bob. I can get you a discounted rate on dyno rental at Works Motorsports at Sonoma Raceway. I've tuned a few Megasquirt setups and would be happy to assist. Cool! I'm 5 miles away from the entrance at my smog shop! Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508650 Share on other sites More sharing options...
Kurbycar32 Posted December 21, 2016 Share #48 Posted December 21, 2016 17 hours ago, LeonV said: I have a feeling that the touchy clutch engagement is due to the clutch and not the flywheel. I'm running a 10lb Fidanza with a stock clutch (at 194hp/180lb-ft at the wheels BTW) and engagement is nice and smooth. FWIW... Thats priceless info Link to comment https://www.classiczcars.com/topic/56686-just-another-damned-project-thread/?page=4#findComment-508678 Share on other sites More sharing options...
