L28 Stroker Build - I need your advice :-)
Line bore (crank), machine the deck, ARP main bolts and verify piston to wall gap (the wrong assumption regarding expansion caused us a set of new in the box custom pistons that were from the parts we got from BSR)
I want to say most but will settle for many L-series engine don't make peak HP or torque over 7000rpm so there is no reason to wind out your new engine to redline with every shift.
Edited by gnosez
Stock camshaft gear will probably give you enough adjustment . What little you gain from the gasket might be offset by any decking of the head. Might just fall in timing on #1 mark
48 minutes ago, german240 said:
Bad news... the crankshaft is bent. Around 0.02" (0.5mm) runout. I'll send it to a specialist, he might be able to fix it.
I have a friend who got bit by the bent LD28 crankshaft, possibly more than once.  I think he stopped trying to get LD28 crankshafts.
I took one of my cranks in to my crank shaft shop I think it was bent about .005" or so but wasn't "straight". They didn't bat an eye, evidently is it not uncommon to see cranks that are not straight. It should be able to be straightened if they can determine where it was bent. If I had to guess I would say it got dropped from a standing position or was thrown during shipping. If they try to straighten it, then it needs to be crack checked really well
Monroe talks about straightening bent crankshafts using a dull chisel in his Rebuild book.  Apparently it's a simple, common procedure.  His point was "don't worry about those chisel marks" if you find some on your crankshaft.
That is the way my crankshaft shop does it. I wouldn't even try it myself :blink: I have run cranks that have been straightened this way, with no problems. The poster's crank though has alot of bend unless he got his decimals wrong! You would need to straighten it exactly where it bent to get it right. I think it's definitely worth a try, otherwise it's scrap...
  • 3 weeks later...
Update: I got the crank back from the specialist. Now it is back to specs!!
Before: 0.17mm (0.0066") runout
After: 0.01mm (0.000393") runout
All the main and rod journals are exactly at the lower wear limit. I'll use standard bearing shells then. I'm actually quite impressed how everything turned out!
I also received a big package with Sean's (Zstory) stainless steel exhaust systems with sport/race equal lenght headers. The "muffler" looks quite nice :D I'm not worried about my car being to quiet anymore.
Edited by german240
  • Who's Online   1 Member, 0 Anonymous, 1,563 Guests (See full list)
