71 240z: Yellow Temp Wire / Black Distributor Wire?
In the yellow and black wire loom going to the temp sensor, my black wire is not hooked up. I thought it went to the distributor. (Spade connector for the old points?). I'm running some electronic distributor of some sort.
I checked the wiring and engine diagram but didn't see it marked anywhere. Just curious. Car runs fine.
On a side note, over the holidays I got the:
- Tach to work
- Brake lights and directionals going
- Cigarette lighter working
- Found out what's wrong with my headlight switch
- New Brake booster installed (Warning Don't lose the clip on the large pin for the pedal. Luckily I found it. Seems the 73-83 pin is the same and available, but not the 70-71.
- Visors and Rear view mirror installed.
  • Who's Online   2 Members, 0 Anonymous, 889 Guests (See full list)
