Redwing Posted January 21, 2017 Author Share #37 Posted January 21, 2017 Just now, Zed Head said: It's under the plastic kick panel. The screws are hard to get to. The pedal in this picture is the clutch pedal. I circled the connector. Thank you for making that clear, and the photos too. I'll have to figure something, I have a hard time bending into that position. As of right now tho, it is impossible. The tow driver got her into the carport leaving only enough room to slide in the door sideways. That will keep me out for sure. Jai Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510741 Share on other sites More sharing options...
Redwing Posted January 21, 2017 Author Share #38 Posted January 21, 2017 Will do, and thank you for the suggestion! I have a healthy fear of electricity. I probably would not have known that without your gentle prod. Jai Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510742 Share on other sites More sharing options...
siteunseen Posted January 21, 2017 Share #39 Posted January 21, 2017 Should she unhook the battery as well as OFF position? I've read that before but have know idea. 1 Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510743 Share on other sites More sharing options...
Dave WM Posted January 21, 2017 Share #40 Posted January 21, 2017 Would not hurt and could prevent forgetting to keep the key off. Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510749 Share on other sites More sharing options...
240260280 Posted January 21, 2017 Share #41 Posted January 21, 2017 Does your 76 ignition system still use the stock ignition box or did you upgrade to the newer 280zx "matchbox" one? If you drive it again and it dies, quickly note the tach and see if it drops to 0 instantly. Also coast along with the gears engaged to see if the tach shows the engine rpm. If it stays at 0 it means no spark. Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510770 Share on other sites More sharing options...
S30Driver Posted January 21, 2017 Share #42 Posted January 21, 2017 I believe her car has the original TIU. Sorry to read of your problems with your beloved car Jai. Did you keep the original ECU, that might eventually come in handy to troubleshoot the problem. Chickenman is right, at least the problem should be much easier to diagnose & correct now. 1 Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510775 Share on other sites More sharing options...
Redwing Posted January 21, 2017 Author Share #43 Posted January 21, 2017 2 hours ago, 240260280 said: Does your 76woutignition system still use the stock ignition box or did you upgrade to the newer 280zx "matchbox" one? If you drive it again and it dies, quickly note the tach and see if it drops to 0 instantly. Also coast along with the gears engaged to see if the tach shows the engine rpm. If it stays at 0 it means no spark. To my knowledge the Ignition system Is stock. My tach does not work. I know It would be a big help. Thank you Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510778 Share on other sites More sharing options...
Redwing Posted January 21, 2017 Author Share #44 Posted January 21, 2017 54 minutes ago, S30Driver said: I b slieve her car has the original TIU. Sorry to read of your problems with your beloved car Jai. Did you keep the original ECU, that might eventually come in handy to troubleshoot the problem. Chickenman is right, at least the problem should be much easier to diagnose & correct now. Yes I do have the origional ECU. Yep I have high hopes that this Is just a temporary setback. I so much have enjoyed driving symptom free. Datsun Z's rule! Thank you... Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510779 Share on other sites More sharing options...
Redwing Posted January 21, 2017 Author Share #45 Posted January 21, 2017 (edited) 13 hours ago, siteunseen said: Should she unhook the battery as Dwell as OFF position? I've read that before but have know idea. Not to worry... I keep key In my pocket when engine work Is being done! Edited January 21, 2017 by Redwing Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-510780 Share on other sites More sharing options...
Redwing Posted January 29, 2017 Author Share #46 Posted January 29, 2017 Hi all, I was talking with a mechanic that has helped me fix my truck in the past. Dean said that RB's symptoms are just like a car he had in the past. Saying that the EGR valve got clogged and the catalytic converter got clogged too. His suggestion was to loosen up the converter at the front edge, and try to start her then. I mentioned oil loss with no apparent way, save the tailpipe is greasy. Yes he said that too. Stalling, stopping, chugging, fouled plugs, agh, cannot remember all we talked about that would be caused by a clogged converter. He said, the combustion has no where to go except building up pressure in the engine, causing many many problems. That all sounds probable to me, but I'm not a mechanic. So I am the messenger, relaying this to you, and asking for your take on it. And I'm asking for any who have had this happen, please tell just what did you do to get your car running good again? Please share with me your efforts and results. Thanks bunches, Jay BTW Deanna watchers, she had a seizure or stroke last night. Still out of it and walking is Very hard, almost can't without help. Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-511344 Share on other sites More sharing options...
Zed Head Posted January 29, 2017 Share #47 Posted January 29, 2017 There's a sticker on the driver's side door jamb that will tell if you have a converter. It was California only in 1976 so you might not have one. I think Nissan called it a Catalyst back then. Mine says NON-CATALYST. Are you saying that engine won't even start now? Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-511345 Share on other sites More sharing options...
Redwing Posted January 29, 2017 Author Share #48 Posted January 29, 2017 Just now, Zed Head said: There's a sticker on the driver's side door jamb that will tell if you have a converter. It was California only in 1976 so you might not have one. I think Nissan called it a Catalyst back then. Mine says NON-CATALYST. Are you saying that engine won't even start now? Zed Head, Thank you for your quick answer. There is no sticker in the door jamb, but I have been under her while on a lift, and saw it. Correct, she will not start now. Never did after I had her towed home. Jai Link to comment https://www.classiczcars.com/topic/56894-somethings-wrong/?page=4#findComment-511347 Share on other sites More sharing options...
