Pulled out my driveline to get easy access to fuel lines (upgrading to 3/8" for turbo charger) on my 1971 240z.
Everyone knows the "while I'm at it" way of doing things.... I'm upgrading my rear end. I purchased the rear end from a 280z 2+2. Its an R200 with the CV axles. I will be stealing the mustache bar as well.
Does anyone know if I'm going to have issues mounting the CV style axles onto my 240z hubs? Or am I going to have to source out some universal style R200 stub axles to get this setup to work properly?
I figured it was easier to strip and paint one set of drivetrain rsther then doing it, then having to upgrade.
Cheers
https://www.classiczcars.com/topic/56912-22-rear-end-in-240z/
CV axles didn't show until about the 1980 280ZX.  Maybe 81.  Got pictures?  Not clear what you're working with.
If you meant 280ZX 2+2 then you could do a hub axle swap.  The 240Z and 280ZX used the same spline count axle and size at the hub.  There are writeups out there.
BUT.  The 280ZX doesn't use a mustache bar.  So, back to not clear what you're working with.
Those are u-joint half-shafts.  You'll have all of the parts you need to swap the R200 in, without extensive work. Your 240Z half-shafts will work, if you are buying the parts separately.  Although a spare set of half-shafts isn't a bad idea.  Get a zerk fitting and regrease the u-joints before installing, if they have the caps over the zerk holes.   I think that you might want the diff mount also, just leave it bolted to the diff.  Although it's probably rotten.
Thanks for the quick reply. I havent actually seen the unit in person yet.
Ill grab the front diff mount as well, but I do plan on doing an RT mount, and if need be I can use it as the sole mount with a urethane bushing.
Once again tha js fir the reply. Ill try and get some cinished photos up too.
  • Who's Online   1 Member, 0 Anonymous, 1,318 Guests (See full list)
