240z Map Light assembly
I was going to order a new lens for my map light in the heater console since mine is missing.  Does this piece just pop in place?  My switch has the spring in it, so i'm assuming that is the spring they are referencing? I thought this is the rocker type push button map light.  One side is fixed so to speak and the return of it to flat is done via the spring loaded switch?
http://www.240zrubberparts.com/apps/webstore/products/show/4424748
https://www.classiczcars.com/topic/56924-240z-map-light-assembly/
  • Who's Online   2 Members, 0 Anonymous, 1,582 Guests (See full list)
