Both my fenders are out in the storage shed but I can check them tomorrow morning if you like,  but the outer edges of the cowling that meet up with the fender at that spot is pretty flat so ... if you have your cowl handy put it up the the edge of the fender and see how it looks.
https://www.classiczcars.com/topic/57017-fender-question/#findComment-512216
5 hours ago, sweatybetty said:
on the top of the fender, between the windshield and front edge of the inspection cover, is this flat or should there be a slight crown to it? both of mine are flat, but it just doesnt look right
thanks all      sb
Just pulled mine off tonight and for the most part I would call that area flat.
https://www.classiczcars.com/topic/57017-fender-question/#findComment-512227
