Help!!! I want to go from an auto to manual...
The last post will work some of the time if you have the right punch. This one works all the time, but will ruin the bushing.
Use a tap for cutting threads the size a little bigger than the trans input shaft. Screw into bushing and when it bottoms out keep turning and the bushing will come out. Many times this is the only way they will come out after 40+ years of wear, but it is fast.
Jerry H
I have been using grease for 30 years to remove the spigot bearing. You might need to "reload" the cavity with grease, but it works and no special equipment required. Just something that fits in the bearing, grease and a hammer.
If the rod or bolt head is to loose you can tape it with some kind of pvc tape. I use a 3/8" socket extension and tape on the racket end until it fits snuggly.
The bearing is also reusable afterwards, if that required.
A puller what work fine and wouldn't be as messy, but I don't have one that fitted. A friend used the tap method and found it work good too.
There is more ways to skin a cat and this is a good example.
Just googled "remove spigot bearing" and found this thread.
Pilot bearing removal.
Chas
  • Who's Online   2 Members, 0 Anonymous, 1,530 Guests (See full list)
