If you have removed the old bushing and take out the metal by mistake you can always put a shim in. That bar is not trash.
Remember that the 240 and 280 bars fit differently (in front or between) the diff/suspension bracket support legs. That is enough room to make the holes line up or in your case not line up.
I ended up making a note to myself where the bar goes (in front or behind) and have marked the bars accordingly, as I swap out diffs for different tracks (R180 - 4:11, 4:38, 190 - 4:44, 200 - 3:90). It would be nice if I had all the ratios in one type of diff.
  • Who's Online   2 Members, 0 Anonymous, 1,530 Guests (See full list)
