Site Updates this Weekend ×
Im looking for cast flattops to rebuild my 83 f54/p79, having a hard time finding ones that arent forged but I stumbled upon these. It says theyre for 75-79s but as far as I can tell those were the same as the pistons in the f54 block. Can anyone see any reason these wouldn't work or if I shouldn't buy from this source?
https://zcardepot.com/engine/engine-rebuild/piston-set-of-6-pistons-l28-020.html?search=piston
https://www.classiczcars.com/topic/57102-question-about-pistons/
You'll end up with a low compression ratio.  The P79 head has a larger combustion chamber and those ZCD pistons are dished.  They'll fit but lower engine performance.
Do you have something against forged pistons or are you trying to save money?  Do you need oversize?  Rockauto has the basic cast pistons that seem to work for a lot of people.
http://www.rockauto.com/en/catalog/nissan,1982,280zx,2.8l+l6,1209350,engine,piston+/+piston+ring+kit,14008
I've read somewhere that Datsun Spirit can get pistons.  https://datsunspirit.com/
ITM makes flat top Pistons for the P79/F54 block. eBay always has these pistons for sale, also a number of vendors do as well. I would make sure the pistons are ITM's, as many of us have successfully used ITM Pistons in the F54/ P79 combo's. However, I don't like their ring sets, so I either use OEM Nissan or Total Seal rings with the ITM's. IMO
Alright, was having trouble finding oversized. Found the ITM pistons .040 over on ebay.
Yeah, the reason I wanted to go cast is the price.
And I plan on staying NA, at least for a good while.
Thanks everyone!
  • Who's Online   2 Members, 0 Anonymous, 926 Guests (See full list)
