hatepotholez Posted February 22, 2017 Share #1 Posted February 22, 2017 so I got my turn signals to work, I was wondering if it's lighting up correctly. I thought only the bottom section(next to the reverse light) would flash not the upper and lower part. Also it looks like I have a ground issue when my headlights and hazards are on? If so where is the ground? Thanks! right turn signal headlights off.mov Hazards headlights on.mov Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/ Share on other sites More sharing options...
SteveJ Posted February 22, 2017 Share #2 Posted February 22, 2017 (edited) https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ Top & bottom should flash. Headlights and hazards have different ground paths. The negative side of the headlight circuit goes from the headlights, through the high/low beam switch and connects to a ground wire at the steering column. The black wire for the ground is shown going all over the place in the wiring diagram, but it does look like it is supposed to use the wiper motor body as one of the places where it is bonded to the chassis. [Edit] I missed two other ground points. One is going to the battery, and the other is the ground in back that I mentioned for the turn signals. The hazard lights are grounded to the same places as the turn signals. Edited February 22, 2017 by SteveJ 1 Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-513621 Share on other sites More sharing options...
hatepotholez Posted February 22, 2017 Author Share #3 Posted February 22, 2017 13 minutes ago, SteveJ said: https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ Top & bottom should flash. Headlights and hazards have different ground paths. The negative side of the headlight circuit goes from the headlights, through the high/low beam switch and connects to a ground wire at the steering column. The black wire for the ground is shown going all over the place in the wiring diagram, but it does look like it is supposed to use the wiper motor body as one of the places where it is bonded to the chassis. [Edit] I missed two other ground points. One is going to the battery, and the other is the ground in back that I mentioned for the turn signals. The hazard lights are grounded to the same places as the turn signals. ok thank you. I do remember reading somewhere that there is a ground near the fuel tank. If I remember correctly I did screw it in, maybe the undercoating is so thick that it didn't ground. I'll check again. Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-513622 Share on other sites More sharing options...
hatepotholez Posted February 22, 2017 Author Share #4 Posted February 22, 2017 I did notice a wire cut that belongs to the turn signal flasher(green) I have to trace this wire and reconnect it. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-513627 Share on other sites More sharing options...
hatepotholez Posted August 2, 2018 Author Share #5 Posted August 2, 2018 On 2/22/2017 at 11:25 AM, SteveJ said: https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ Top & bottom should flash. Headlights and hazards have different ground paths. The negative side of the headlight circuit goes from the headlights, through the high/low beam switch and connects to a ground wire at the steering column. The black wire for the ground is shown going all over the place in the wiring diagram, but it does look like it is supposed to use the wiper motor body as one of the places where it is bonded to the chassis. [Edit] I missed two other ground points. One is going to the battery, and the other is the ground in back that I mentioned for the turn signals. The hazard lights are grounded to the same places as the turn signals. Getting back to this. The JDM lights have amber turn signals, is it different for that market compared to ours? Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-554364 Share on other sites More sharing options...
siteunseen Posted August 2, 2018 Share #6 Posted August 2, 2018 Seems like the US cars were all red, Europe and others required amber. If I remember right. I bought mine from futofab.com and love 'em. 3 Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-554380 Share on other sites More sharing options...
cgsheen1 Posted August 2, 2018 Share #7 Posted August 2, 2018 2 hours ago, hatepotholez said: Getting back to this. The JDM lights have amber turn signals, is it different for that market compared to ours? Yes. And they wired differently. The red lens should be a 2-filament bulb for "park" and "stop" lamps. The amber should be single filament and used only for turn signal and flasher. 1 Link to comment https://www.classiczcars.com/topic/57118-tail-light-issue/#findComment-554381 Share on other sites More sharing options...
