I'm probably the youngest... Only 15. Nice car by the way. Good luck with the restoration and have fun!
Oh wow, suddenly i found a grey hair. [emoji23] and thanks
Space_cowboy '74 260z
Curious, is there a reason you pulled the head and engine? Was it bad?
Wanted to see how bad it was. What kinda measures i had to take in restoring it. Its not bad i came to find out. Just dirty
Ah ok. Just a suggestion in the future I would have not pulled it apart. Simply make sure it has good compression and see how it runs. The L6 engines are pretty stout and either run great and have been cared for or worn out and smoke like crazy, with a few in betweens!
That's understandable. I don't think i mentioned it sat for 20 years not running. First thing i wanted to do was make sure every bit of the car was in shape to run and if not then to replace it. I just want to be thorough. I hate having to go back and do something over simply because i assumed.
  • Who's Online   0 Members, 0 Anonymous, 1,476 Guests (See full list)
