Those are two separate parts on my '77.
Can you not clean them up enough, shiny brass, or is it the connections that are bad?
I found my thermotine sensor at a junkyard, they are high as a giraffes arse everywhere else.  Temp sensor are available at rockauto.
I just thought of something.  The connectors are the same and people hook them up wrong all the time.  You may just swap the plugs around and get back working.  If I remember right thermotine is brownish, temp gauge is greenish or off white?
My temp gauge sensor has a single wire, bullet connector.
Edited by siteunseen
1 minute ago, tim hickernell said:
if I clean the brass would that maybe work ?
Yes.  Calcium from the water covers them over the years and they lose their sensitivity. Wire wheel, sandpaper whatever you have that won't gouge it.  Clean all three. The wire on the temp gauge may need the female end squeezed together
Thanks again I will try that
3 minutes ago, Dave WM said:
you should get a service manual, it will help you with what does what.
I will look online
