tim hickernell Posted March 1, 2017 Share #1 Posted March 1, 2017 I have a 1980 looking for a temperature sending unit or might be called a thermo time switch Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/ Share on other sites More sharing options...
siteunseen Posted March 1, 2017 Share #2 Posted March 1, 2017 Those are two separate parts on my '77. Can you not clean them up enough, shiny brass, or is it the connections that are bad? I found my thermotine sensor at a junkyard, they are high as a giraffes arse everywhere else. Temp sensor are available at rockauto. Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514142 Share on other sites More sharing options...
Dave WM Posted March 1, 2017 Share #3 Posted March 1, 2017 different things. there is a temperature sending unit for the temp gauge there is a thermotime switch for the cold start circuit there is a temp sensor for the EFI enrichment circuit. Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514143 Share on other sites More sharing options...
siteunseen Posted March 1, 2017 Share #4 Posted March 1, 2017 (edited) I just thought of something. The connectors are the same and people hook them up wrong all the time. You may just swap the plugs around and get back working. If I remember right thermotine is brownish, temp gauge is greenish or off white? My temp gauge sensor has a single wire, bullet connector. Edited March 1, 2017 by siteunseen Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514144 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #5 Posted March 1, 2017 Thanks mine is by the thermostat housing has 2 connectors the plugs in Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514145 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #6 Posted March 1, 2017 if I clean the brass would that maybe work ? Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514146 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #7 Posted March 1, 2017 my gauge on the dash does not work Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514147 Share on other sites More sharing options...
Dave WM Posted March 1, 2017 Share #8 Posted March 1, 2017 you should get a service manual, it will help you with what does what. Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514148 Share on other sites More sharing options...
siteunseen Posted March 1, 2017 Share #9 Posted March 1, 2017 1 minute ago, tim hickernell said: if I clean the brass would that maybe work ? Yes. Calcium from the water covers them over the years and they lose their sensitivity. Wire wheel, sandpaper whatever you have that won't gouge it. Clean all three. The wire on the temp gauge may need the female end squeezed together Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514149 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #10 Posted March 1, 2017 1 minute ago, siteunseen said: Yes. Calcium from the water covers them over the years and they lose their sensitivity. Wire wheel, sandpaper whatever you have that won't gouge it. Clean all three. The wire on the temp gauge may need the female end squeezed together Thanks again I will try that Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514150 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #11 Posted March 1, 2017 3 minutes ago, Dave WM said: you should get a service manual, it will help you with what does what. I will look online 4 minutes ago, Dave WM said: you should get a service manual, it will help you with what does what. Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514151 Share on other sites More sharing options...
tim hickernell Posted March 1, 2017 Author Share #12 Posted March 1, 2017 OK I am going to try the things you suggested bye Link to comment https://www.classiczcars.com/topic/57161-1980zx-need-a-thermo-time-switch/#findComment-514152 Share on other sites More sharing options...
