On 3/11/2017 at 1:24 PM, Zed Head said:
There's a ton on the internet.  But many of these old engines have been worked on and made to run with the distributor off a tooth or two.  The best thing to do is to set the timing mark on the damper pulley to zero, on the compression stroke of cylinder #1, then set plug wire #1 in the cap to wherever the rotor under the distributor cap is pointed.  Then plug in the rest of the wires in a counterclockwise direction,in the order I showed.
Zed, im in the middle of this right now. with the distributor off by 1 tooth, there isnt enough adjustment either way to get total advance and base advance at the same time. switching plug wires over 1 hole gives the opposite problem. im going to pull the oil pump for the 3rd time tomorrow just to make sure its right. very aggravating!
  • Who's Online   1 Member, 0 Anonymous, 1,366 Guests (See full list)
