Replacing exhaust system on my 72 240z from the manifold to the back
Nick,
I sent you an e-mail. Please do not forget to send me the video or pics of your installation. How loud is this msa stock exhaust system? can i still listen to the radio with it?
Nick,
Okay sounds good I'm getting it out of storage when I get off work today so I can send some more detailed pictures as well.
You will love the sound I promise
thanks to all of you. I finally took the car the shop and had the MSA Premium Exhaust installed. Nice sound when i speed up and low rumble at idle. I was wondering if i would need to tune up my carbs back again due to the new exhaust which has a diameter of 2.5 " instead of the former 2"? Will i need to set up the mixture in both carbs, idle speed and balance? Or the new MSA exhaust does not affect the actual setup?
Edited by jalexquijano
Did you get the heat reducing ceramic coated header to?  I hope so, it really cuts the engine bay heat while running and cools down much faster than the bigger cast iron factory manifold.
i just got the MSA PREMIUM EXHAUST 70-72 Stock manifold kit!
http://www.thezstore.com/page/TZS/PROD/15-6302
Any additional recommeded part i should buy to cool the heat and avoid this problem!!
Same order I placed and didn't need anything else.
Nick,
I already had the msa Premium exhaust kit installed. I did noticed there is some detonation when i let the gas pedal go and more pronounced if i go down a hill. Is this normal?? Both of my 72 round 3 screws SU CARBS are tuned and balanced correctly. If i lean the mixture i will have detonation at the intake. Are the gasket sold by MSA good enough? My original stock system was 2". THis one is 2.5"
  • Who's Online   0 Members, 0 Anonymous, 1,608 Guests (See full list)
