TheErictag Posted March 29, 2017 Share #1 Posted March 29, 2017 Ok so I've sourced a r200 out of a 79to put into my 240 but what is the best way to make it two legged .. I know a good rear end shop in the area but any of y'all ztards have a link I can go learn a bit before I go in to the shop babbling about buying a queef or some other bs to em.. @queef. Quaiffe?? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/ Share on other sites More sharing options...
Zed Head Posted March 29, 2017 Share #2 Posted March 29, 2017 19 minutes ago, TheErictag said: ztards Wrongness. Don't do this stuff. OBX, MFactory, 87-89 300ZX. Whitehead Performance. Those are your fundamental search words. 1 Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516667 Share on other sites More sharing options...
grannyknot Posted March 29, 2017 Share #3 Posted March 29, 2017 You can start here and then just scroll through the drivetrain section, many, many threads dealing with LSD, OBX, Quafie,... http://forums.hybridz.org/topic/101977-helical-limited-slip-function-and-torque-bias-ratio/ http://forums.hybridz.org/forum/83-drivetrain/ Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516678 Share on other sites More sharing options...
TheErictag Posted March 29, 2017 Author Share #4 Posted March 29, 2017 No offense meant zed head. I thought it sounded kinda cool and was witty but no more. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516692 Share on other sites More sharing options...
7tooZ Posted March 29, 2017 Share #5 Posted March 29, 2017 Eric, I will offer my experience for what it’s worth. I recently did this conversion to my (Series II) 72 240z so that is where my knowledge is at. I is always helpful when you start a new thread that you should provide the basics about your car. As I recall you have a Series III 240. 4-speed? And you have acquired 79 R200? Do you know what model the diff came out of? 280zx 2+2 4-speed? 280zx 5 speed? 280zx-GL? Do you have: 29 spline stub axles? R200 Mustache Bar? Half shafts that connect to your stub axles and your outer Hubs? mounts for diff both front and back? what condition your Ring & pinion are in? Drive shaft, will it work with the current transmission and the R200? What is the gear ratio in the R200? Are you going to keep? Will it work well with your current transmission ratio? How are you going to use your car? Buying a LSD is a search your will need to read up on. The searches specified above is where to find the research. Expect to pay $900 - $1500. Installation cost into the R200 could be around $500+- depending on the condition of the Diff. Most seller require proof of a professional to install it, if you want to maintain any warranty coverage Last can you do the installation in to your car yourself? Lets know where we can assist. 1 Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516701 Share on other sites More sharing options...
TheErictag Posted March 29, 2017 Author Share #6 Posted March 29, 2017 Yes I'll install it myself. I have the knowledge needed and all the tools. I'll have the rear ended rebuilt professionally with the part(s) needed to make it happen. As for the trans it's a close ratio 5speed. I'll get the azc mustache and brackets. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516703 Share on other sites More sharing options...
TheErictag Posted March 29, 2017 Author Share #7 Posted March 29, 2017 The car it's coming from is a 2+2 so should have the 3.90 gearing. It'll light it up I'm sure. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516712 Share on other sites More sharing options...
EuroDat Posted March 29, 2017 Share #8 Posted March 29, 2017 You might want to check the ratio. The 79 280ZX is a bit odd in the ZX line up. 280ZX 1979 2+2 4 speed R200 3.364:1 280ZX 1979 2+2 5 speed R200 3.7:1 ( also had wide ratio 5 speed like 280Z) 280ZX GL 1979 R200 3.7:1 The coupes used a R180 with 3.364:1 ratio. The 2+2 manuals went to the 3.9:1 in 1980 and all NA manuals (coupe and 2+2) were 3.9:1 from 1981 - 1983. Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516727 Share on other sites More sharing options...
7tooZ Posted March 29, 2017 Share #9 Posted March 29, 2017 I don't believe any of the 79 2+2s had a 3.90?Don's iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516728 Share on other sites More sharing options...
TheErictag Posted March 29, 2017 Author Share #10 Posted March 29, 2017 Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516729 Share on other sites More sharing options...
TheErictag Posted March 29, 2017 Author Share #11 Posted March 29, 2017 3.70 ain't bad I read the wrong columnSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516730 Share on other sites More sharing options...
EuroDat Posted March 29, 2017 Share #12 Posted March 29, 2017 I have a 3.7:1 behind a close ratio 5 speed. The tranny and diff didn't come from the same donor car. The PO did the transmission and I changed the diff. The diff improved the drivability. First was too high with the 3.545:1 diff. I like it. 1 Link to comment https://www.classiczcars.com/topic/57372-making-a-one-legged-into-limited-slip/#findComment-516733 Share on other sites More sharing options...
