I managed to get the intake bolts off without any bolts or studs breaking, I also got all the exhaust bolts off except one. I am letting that one soak a bit more before I give it another go.
I could cut the last bolt off, just carefully split it with a dremel. The heat shield was the biggest pain, I cut it off from the top with a dremel. I have replacement shields and and a new intake that was powder coated so I didn't care if I damaged the old one. I am putting a coated header on and really wonder if it necessary to put on the heat shield. What say y'all?
I say yes.  If it's a 280 the shield will need trimming, I'll post a picture of what I did in the morning.  They keep the heat off your PCV hose and the master cylinders for the brakes.  The coated header from MSA is what I have and they do a remarkable job dissipating heat, fantastic headers IMHO.
If it's a 240 they keep the heat away from the carbs, percolation or hot restart prevention.
Here's where I trimmed mine, the red circle.  The other red circle is where my header touched the bellhousing.  Had to grind that down a little to keep it from rattling.  maybe your's won't hit there.
I used tin snips to cut that with then went back and sanded the edges then VHT spray paint.
Edited by siteunseen
Thanks for the info! I have a 3-2 header, doesn't look like it will contact the bell housing, we will see. I have a long road ahead of me before I get to that point. I am waiting for all the metal components to come back from plating. I am also considering at this point if I should just pull the motor so I can properly clean the engine compartment properly. The most intimidating thing to me is the AC system which works well. Not sure how I would go about discharging the system properly. It's has the old refrigerant which is really costly to replace as well.
IMG_1491227309.481338.jpgIMG_1491227326.246925.jpg Here is where I am at now, lots of cleaning ahead.
 I considered pulling mine also when I wanted to clean the engine bay.  The cons outweighed the pros in my case except for the radiator, I did pull that and have it flushed, then I repainted it.
I wound up doing one side at a time, unbolting everything and taping some hoses that couldn't  get out of the way.  Cleaned, degreased then repainted with colored matched enamel from the Automotive paint store as I went. Re-attached it all and was done (one side at a time, including the firewall.   It was a little time consuming but I didn't have to remove the hood and wrestle anything else.   If you are not painting, It should be even easier.  That is also a good time repaint the block if you desire and steel wool the copper A/C lines when you are there.
Before and after shots.
Edited by gwri8
Added pictures
  • Who's Online   2 Members, 0 Anonymous, 1,172 Guests (See full list)
