21 hours ago, gwri8 said:
Can't you just slip one of these in the fuel tank?
6 hours ago, jalexquijano said:
why the offense? trying to solve fuel percolation at idle during traffic jams and you come up with this?
No offense intended, it's a joke about Viagras ability to make an older man (or car in your case) preform like a young man (or car).
If you try this beware that any effects lasting longer than 4 hours you should see your mechanic, FYI.
On ‎04‎/‎21‎/‎2017 at 10:57 AM, Jarvo2 said:
I'm hoping you've referenced the attached fuel system modification guide, right?  Just one of the many bits of documentation that I've collected over the years.
Fuel-1973 240z 1974 260z fuel system modifications.pdf
Jarvo,
I had downloaded it a year ago and once read, i decided to look for a stainless Steel heat shield extensión  that covers both floats bowls of the 3 screws carburetors on my 72. Anyway today i swapped the complete exhaust of the car with the MSA PREMIUM EXHAUST which has a 2.5 diameter pipe and xlerator turbo  muffler. Once finished i drove out of the shop and got into a 10 minute traffic with lot of heat fron the road.. idle became lumpy until the car died 2 times. I decided to order a Malpassi glass filter and regulator  (85mm versión) to regulate any excess of fuel:
http://www.ebay.com/itm/Malpassi-Filter-King-Fuel-Pressure-Regulator-and-Gauge-clear-glass-bowl-/110622432307
If pressure is too high, this will be the symptom? I still dont want to remove the Steel fuel rail!! WHo else had this problem and solve it? I already wrapped the Steel fuel rail and installed a heat shield extensión. What else????
Edited by jalexquijano
 Jarvo2, Yeah, that cam has always been kind of lurking in the back ground.  It can't be helping the situation, that's for sure.
 jalex, Do you know anyone else in Panama that has a Z. I'm curious if anyone else there is fighting or has solved the problem?
19 minutes ago, Jarvo2 said:
I'm still of the opinion that its your hot cam from California Datsun.  Get a stock head that's rebuilt to factory specs.
California Datsun LLC?  :cry:
Edited by siteunseen
  • Who's Online   0 Members, 0 Anonymous, 1,629 Guests (See full list)
