1976 280z Can anyone sell me a Thermostat Housing
When you do find a replacement. replace the top bolts with short studs. No more problems with seized bolts. The studs are " standard hardware " items from any Japanese car parts dept. You just gotta find a Partsman that doesn't have to ask you... what you and model is that for. That can be the tricky part.
7 hours ago, charliekwin said:
I'm running a ZX housing on my 78. Nissan moved some of the sensors around in the housing, but it works fine. That housing would probably fit in a 76 too (confirm first!), so that might help with your search.
I've got a '79 ZX housing.  I'll try and find it today, let you know asap.  I thought he may have to plug a hole or two but that's no big deal.
@SeKcGamer I found one in my pile.  It looks good and comparing it to my '77 it's ALMOST identical. One of the coolant lines to the AARs warming plate is a little longer.
I don't have a warmer with coolant so those are plugged on my car. Thermotine switch is different but I think all the threads are the same throughout the years?
$30 and you pay fedex. I'll check back every 30 minutes or so.
[mention=30892]SeKcGamer[/mention] I found one in my pile.  It looks good and comparing it to my '77 it's ALMOST identical. One of the coolant lines to the AARs warming plate is a little longer.
I'll let you know later in the afternoon if I can take it from ya. I'm currently at school in my auto mechanics class[emoji23],[emoji28]
Sent from my iPad using Classic Zcar Club mobile
12 minutes ago, SeKcGamer said:
I'll let you know later in the afternoon if I can take it from ya. I'm currently at school in my auto mechanics classemoji23.png,emoji28.png
okay. You're not in a hurry thank goodness.
I'm pretty sure it would work, maybe somebody can say for sure. It'll be here.1492701982467.jpg
33 minutes ago, SeKcGamer said:
Sent from my SM-J320V using Classic Zcar Club mobile
They called it vocational school when I went in high school. 10am until 2:30pm we went to goof off at the technical college.
Keep your nose clean!
Wear a respirator. LOL
Is that a Chevy Biscayne I see?  My dad had one of those when I was very little.  I remember those fins!
It's a Chevy something[emoji23]. The one right next to it is a datsun pickup
