My aluminum three row doesn't have a draincock installed (???).  Rather than pulling the lower radiator hose every time, and making a mess, I'd like to install a draincock.  I figure this will involve drilling / tapping which is fine, but I foresee tiny shards of aluminum making their way downstream. :(
 Suggestions?
https://www.classiczcars.com/topic/57535-radiator-needs-draincock/
You will have to take it out and have a radiator shop or someone that can tig weld aluminum.  Regarding the fear of metal shavings I am sure the shop would thoroughly flush it out as part of the repair.  Shocking that it does not have a drain **** on it.  Who is it made by?
Thanks Hardway, yeah I'll probably take it out as you suggested. This radiator is from Arizona Z Car 11 years ago, and it is considered a racing radiator even though I don't race.
I just gave them a call, I think I talked to the owner, and he said they do not install a draincock because they feel that it could get knocked off since the bottom of the radiator is 2 inches lower than a stock radiator. I think one could easily be installed because it still sits higher than the oil pan.
Thanks!
If anybody else is interested:
A little research turned up an aluminum bung to weld to the bottom of the tank:
http://www.jpcycles.com/product/721-343
And an all aluminum draincock from the Corvette guys:
http://corvettespecialty.com/corvette-aluminum-radiator-draincock-1960-72
I haven't checked on sizing yet but I imagine 3/8 being standard.
  • Who's Online   1 Member, 0 Anonymous, 1,507 Guests (See full list)
