MSA Exhaust system 2.5" gasket replacement pipe to pipe
Im looking for a better 2.5" 3-bolt gasket replacement for the pipe to pipe gasket supplied by MSA in their kit:
http://www.thezstore.com/page/TZS/PROD/15-6302
I have read i should purchase Nissan to avoid any leak as the ones supplied by MSA are not high quality. Any recommendation?
back the timing closer to spec and see if that decreases the popping.
Didn't you say yesterday an exhaust shop said there was no leaking? That's who would know and will have high quality gaskets if needed.
Timing is set to 16BTDC as it runs smoother. The shop says there is no leaking and they do not sell high quality gaskets. Some people even say it normal to have popping at exhaust!
Edited by jalexquijano
