Alright, sounds like you're in a rush then.
If the backing is still good on your current panels, then skins from Les might be an option at $275.
We now have available door skins for the door panels on your 240Z. These are a very nice reproduction of the original pattern and can be installed on your existing door hard boards.  Send us your complete panels and our factory will install the new skins.
http://www.classicdatsun.com/
https://www.classiczcars.com/topic/57660-door-panels/#findComment-520166
The backings are made of the same material as the spare tire cover is made of. I thought about a project but matching the couture of the door seems a bit of an issue. You must be near the finish line if the interior is what you are working on. FORGET THE GUNS............RAMMING SPEED!:D
https://www.classiczcars.com/topic/57660-door-panels/#findComment-520248
  • Who's Online   2 Members, 0 Anonymous, 1,478 Guests (See full list)
