1 hour ago, grannyknot said:
Geez, I sold one like that last year for $80. Have you tried @zKars he's got a lot of stuff.
$80?!?!?!?!?   That there is a $300 dollar antenna if it works and is complete!
And no I don't have one. I don't think.....
Edited by zKars
https://www.classiczcars.com/topic/57709-series-i-antenna/#findComment-520750
Interesting.  I have on from my 70 Z with exactly the same granulated surface deterioration of the slotted black plastic 'grommet'.  I was going to try to replace it, but now I can see that it's actually 'patina'.
So that means my selling price just went up by 100%.
Bids?
https://www.classiczcars.com/topic/57709-series-i-antenna/#findComment-520752
The early antenna has an 'arrow' tip and the later ones have a more flat / squareish tip (on the mast).
While on the topic anyone found a donor mast that could be used in place the original (which is often broken)?
I've found quite a few motors but the tip or mast is broken...
https://www.classiczcars.com/topic/57709-series-i-antenna/#findComment-520838
My 5/72 production car, has 40,000 miles and the original pointed tip antenna,  It is the exact same antenna as far as I  can tell as my four 1969 production cars and my 1970 Z-L.  I don't think there are any differences in original antennas up through 1973 at least.
Edited by Mike B
  • Like 3
https://www.classiczcars.com/topic/57709-series-i-antenna/#findComment-520842
