 How do you know you didn't blow the fuse? Did you check it with a meter?
Do you have the correct bulbs in for the side markers, turn signals and tail lights?
Inspect for corrosion at the side markers. That will come into play later.
Edited by SteveJ
Didn't read the topic title carefully
Also, check the 6 wire connector under the dash, specifically at the green/white and green/blue wires. Those are the ones that the parking light switch connects.
The reason why I asked about the bulbs is that it is easy to replace the stock bulbs with 1156 and 1157 bulbs. While those bulbs will work in the sockets, they draw more current than the 67 and 1073 bulbs specified by Nissan. The extra current can cause heating at connectors with that one (and the fuse box) being the most vulnerable. The heating can cause damage without blowing the fuse.
