Hi there Mike Hill , you should find the item you are after, in the lower thermostat housing. the thermal transmitter should have yellow coloured wire attached and the Water Temprature switch should have a white coloured wire attached.
You may also find that your set up does not run what you are looking for you may find your management system is using a cylinder head temp prode.
I suggest taking a look at the thermostat housing if you have two positions with wires.
Cheers
Steve :classic:
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
