This is the check valve. I removed these from my car when I installed disk brakes in the rear. Disk brakes don't need check valves.
When you get a chance, try taking them out and see if it helps.
20 hours ago, Jaymanbikes said:
I got another master installed it, shimmed it out, still same issue as the first go round, system is holding pressure. Here is what I have under the adaptor in the ZX master.
I will give it a rip when I get sometime to experiment, reinstall the master.  Weird the ZX master is designed for a car with Disc front brakes to the best of my knowledge.
  • Who's Online   1 Member, 0 Anonymous, 1,187 Guests (See full list)
