Still trying to salvage mine.  Welded in patches, welded up pin holes, etc.  Filled with water/acid solution and it leaked like a sieve.  So, stripped all the paint off the tank and covered the entire tank with thickened epoxy resin (did bottom half, have top have to do).  Afterwards, I will acid wash again and line with Red Kote...time will tell if this works.  But, regardless, the metal is very thin in places...not ideal.
Bought one today on Ebay for $350 just in case.
  • 1 month later...
