Skip to content
Rear side marker lights blows headlight relay fuse and vice versa
Hi everyone:
I have my headlights on a 5 pin relay with 87 +12v battery (with a 10A fuse on each), 30 output to LB/HB, 86 headlight on/off switch, and 85 ground to LB/HB dimmer. I noticed my rear side passenger marker light was out so I replaced it. But when I switch on the headlights it blows the 10A HB fuse. However if I replace the 10A fuse and put back in the burned out bulb into the rear side passenger marker light socket I don't blow the headlight 10A fuse when switching between hi/low beam.
Don't the running lights route through the hazard switch and the headlights through the combo switch? I don't how how the headlight and running light would short/open one another?
Howard
1974 260z
Edited by 882993md
