Iam in the process of installing an new ignition coil that came with its own white resistor block. It has a wire that goes from resistor + to + on the coil.
My issue is that the new resistor as two attachment point were as my original resistor has three attachment point. (Early 74/260Z).
The original connections goes like this; the small cylinder (condenser?) is connected to the + of the coil than a blue wire from harness goes to coil negative. White/black wire from resistor negative to + coil
Black/White wire from harness goes to + resistor
Black/Blue from harness to its own pole on resistor.
Black wire from harness to - resistor to positive coil via white/black wire. (Black and White/black connected together at the resistor negative).
My question is how to I attach all the wire to the new coil and resistor which has only two attachment point?
Thanks in advance.
https://www.classiczcars.com/topic/58010-new-coil/
  • Who's Online   2 Members, 0 Anonymous, 1,527 Guests (See full list)
