Posted July 7, 20178 yr comment_525087 A little backstory… I’m servicing the R-200 rear axles on my ’77 280Z that I installed in the late ‘80s when the orig. pair started to seem a bit dodgey. I don’t remember where I got them, but they don’t match exactly in casting/markings and hardware. However, they both are for the same application, with the same press-in U-joints, and have worked well since the original install. Same internal details in every way save one: the Factory-looking one had the requisite 12 nylon ball spacers, while the different-looking one had but 8. Su-prise, su-prise. So, here I am, hoping that someone out there just might have 4 of the spacers that they could let go of. Oh yeah; if I saved the old axles, they are hiding exceptionally well. Thanks Link to comment https://www.classiczcars.com/forums/topic/58071-rear-axle-parts/ Share on other sites More sharing options...
July 7, 20178 yr comment_525089 Hey, I replied to your zcar.com thread too. (You really shouldn't post on two threads at the same time. Give one a chance...) Compare the 1976 illustration with 1977 and you'll see that what I described there actually is right. Nissan removed a spacer per groove in 1977. Link to comment https://www.classiczcars.com/forums/topic/58071-rear-axle-parts/#findComment-525089 Share on other sites More sharing options...
