cin Posted July 16, 2017 Share #1 Posted July 16, 2017 1981 280 zx turbo crank sensor part number 23731 V0801 discontinued can part be rebuilt what would I have to do to re modify need help any thing you could do would be greatly appreciated please answer Thanks Cin Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/ Share on other sites More sharing options...
Patcon Posted July 16, 2017 Share #2 Posted July 16, 2017 http://www.rockauto.com/en/catalog/nissan,1981,280zx,2.8l+l6+turbocharged,1430312,ignition,crankshaft+position+sensor,7196 available on Rockauto Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/#findComment-525867 Share on other sites More sharing options...
zKars Posted July 16, 2017 Share #3 Posted July 16, 2017 (edited) Cin I'm thinking you mean the one on the crank pulley correct? The 81's had a rig on the timing cover and a toothed wheel on the crank pulley. They moved all that to the dizzy with a nice optical thingy in the 82-83 Edited July 16, 2017 by zKars Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/#findComment-525869 Share on other sites More sharing options...
Zed Head Posted July 16, 2017 Share #4 Posted July 16, 2017 2 hours ago, Patcon said: http://www.rockauto.com/en/catalog/nissan,1981,280zx,2.8l+l6+turbocharged,1430312,ignition,crankshaft+position+sensor,7196 available on Rockauto That's the right car but Rockauto has the wrong part for it. 1981 was unique. Their compatibility table shows that it's for the later distributor style sensor. You have a big problem. You can convert to the distributor mounted sensor easily but those are hard to find also. borini63 has always been good for old ZX parts. @borini63 Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/#findComment-525872 Share on other sites More sharing options...
Patcon Posted July 16, 2017 Share #5 Posted July 16, 2017 Thanks Zed Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/#findComment-525882 Share on other sites More sharing options...
cin Posted July 17, 2017 Author Share #6 Posted July 17, 2017 thanks for all the input I have sent a message to borini63 I found the one at Rock auto but after I talked to them I knew it was not right. If any one has ever changed out the distributor any input that you could send me would be appreciated Cin Link to comment https://www.classiczcars.com/topic/58133-crank-sensor/#findComment-525902 Share on other sites More sharing options...
