Disconnect the EFI system by disconnecting the fusible link or fuel pump power and see if it runs better with just starting fluid.  If it still runs bad then it's not going to run better with carbs.  There's no magic bullet, even with carbs.
  • 3 years later...
On 1/16/2018 at 10:35 AM, Zed Head said:
As site says it should start without any of those broken items.  Except for the BCDD and the dash pot they are all to make cold starting and running easier but shouldn't stop it from starting.
Maybe add some details about what it sounds like when it's turning over.  You said that you have spark and fuel.  Are you even getting a pop?  Spark plus gasoline almost always gets at least a pop.
Where can I get that bcdd connector if mine is broken like that?
