The tach counts sparks.  The module could be sending extra pulses to the tach.
You're going to need to find a full size computer and download the 260Z Factory Service Manual.  The details of how to remove the tach are in it.  It comes out from the front.  http://www.classiczcars.com/files/category/12-260z/
Your car is a 1974 model.  SteveJ knows the 260Z but he likes a good description of the problem.  Your forum style might not work.  Worth a shot though - @SteveJ
Good luck.  Add your location to your profile.
https://www.classiczcars.com/topic/58174-steved/#findComment-526273
Another possibility, though it may be remotely is the resistor is dying or not making good electrical contact. I say remote because resistors usually fail open or closed, not displaying intermittent failures while dying.
Sent from my SM-S320VL using Classic Zcar Club mobile
https://www.classiczcars.com/topic/58174-steved/#findComment-526282
  • 3 weeks later...
If you still need some answers to your questions...
There are two screws holding the tach in that are accessible from under the dash and under the top overhang of the tachometer hood. Once these are out, I think you just reach back and push the tack forward and pull it out from the front. You might need to remove the steering wheel to get it out. If you have a dash cap installed, it will likely need to be removed.
Your can then attach lead wires to it. One to the + side and one to the - side of the battery, then one more to the - side of the coil after first passing through a 50 kohm resistor. That will at least tell you if the tach is at fault or if it's a problem with a loose wire or bad resistor. Let me know if you need a resistor. I have extra after setting up some test leads for this very issue.
Jeff
https://www.classiczcars.com/topic/58174-steved/#findComment-527695
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
